A.Smo Posted May 1, 2012 Report Posted May 1, 2012 I need some help designing a box for the SA-8 V.2. I have the max dimensions of 15"h x 20"d x 40"w. I have tried a few different things on the Torres calculator but can't seem to get it right. Any help would be appreciated. It will be going in a Saturn Ion2, with a HFi 1000.1D for now on stock electrical, but will be upgrading to an AQ 1200D, extra battery and Big 3 here shortly. Thanks! Quote Sub Stage: Sa-8 V.2 in a .72 cu ft box tuned to 33 hz AQ 1200D Upgrades: Big 3 Battery Bought from: Kevin@skaraudio, RooTxBeeR, UtkNate, dgaf
Joe X Posted May 1, 2012 Report Posted May 1, 2012 If it's sa-8v2 D2 I think that your current amplifier is ok the sub is rated at 500W, here is a sample design, 3 common walls slot port, use it to Learn Torres or build it: Enclosure Specifications: Fb = 35.3 Hz Vb = 0.72 ft^3 External Height = 10 in External Width = 22 in External Depth = 12 in Port Width = 1 1/4 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front & Back = 22 x 10 Left & Right Sides = 10 1/2 x 8 1/2 Top & Bottom = 22 x 10 1/2 L Port Internal Assembly Parts: Front to Back = 9 1/4 x 8 1/2 Extension = 16 1/4 x 8 1/2 Assembles like this: Quote
A.Smo Posted May 2, 2012 Author Report Posted May 2, 2012 Thanks Joe x! I had tried something similar, but couldn't quite figure it out. And yes, it is a D2. I knew I had forgot something. Thanks again. Quote Sub Stage: Sa-8 V.2 in a .72 cu ft box tuned to 33 hz AQ 1200D Upgrades: Big 3 Battery Bought from: Kevin@skaraudio, RooTxBeeR, UtkNate, dgaf
IanJohnson Posted May 2, 2012 Report Posted May 2, 2012 hey, if that doesnt work for you, look at my build log and you can look throughout the build to see if you would want to build it, it meets your max deminsions and is tuned around 33hz after sub displacement, Quote Duel Sa-8 V.2 D2 Sub Enclosure 2001 Pontiac Grand am Head Unit - OEM Processor - RF 3sixty.2 Subs - RE Audio SXX12D4 Amplifier - Kicker ZX1000.1 Mids & Highs- Rockford Fosgate Power T2652-S Rockford Fosgate Power T1693 Mids & Highs Amp - Rockford Fosgate Power T400-4 Wiring - 1/0 AWG, 4 AWG, 8 AWG Alternator - Stock Batteries - non ext Box- Absolute PSEB12BK
