Am i stupid or is hooking anything other than your subs to your amps speaker terminals going to change what ohm's the amp see's and thus possibly frying the amp? From what i gather you just need a module that has a microphone that tells the lights when to light up. Correct me if i am wrong.
I don't want those lights flashing when I have a lady friend in the vehicle...... :ninja:
POTATO!
You have something against mood lighting? :P
Yep, it will for sure change the load the amp sees
2000 Subaru outback 2.5l
Head Unit: Pioneer deh 4300ub
front stage: tbd
subwoofer: Stock Fi Q 18"
amp: Audio que 1200d
Look up color changing led strips
Or the music controler
Anyother led option basically sucks
Sodering leds to resistors is the lamest thing you can do.... just buy the 12v kits!
I I talk from experience the tlines I built, the first one had massive led problems I've had 7 out of the 20 or so on there go out multiple times
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
can i wire them to the 6x9 in the trunk instead of my subs. would that be better
no.
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
ok?
the same thing would end up happening.
you can either;
A: go about it in the way you've been advised to by people on here,
or
B: do it your own way and fuck shit up.
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
so get some resistors or a box? correct
yupyup
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
  • Who's Online   0 Members, 0 Anonymous, 827 Guests (See full list)
