greenlight00 Posted May 6, 2012 Author Report Share Posted May 6, 2012 I have the chassis groud and the engine ground on the transmisson ( stock location). The amp is grounded directly to the rear battery, and the rear battery is grounded to the back left strut tower bolt. All grounds are solid... Quote Link to comment Share on other sites More sharing options...
Guest Posted May 6, 2012 Report Share Posted May 6, 2012 paint/grime sanded off on all added ground points? shiny metal Quote Link to comment Share on other sites More sharing options...
greenlight00 Posted May 7, 2012 Author Report Share Posted May 7, 2012 Yessir Quote Link to comment Share on other sites More sharing options...
MIKE-2U Posted May 7, 2012 Report Share Posted May 7, 2012 check voltage at the alternator at full tilt. Check you stock battery at full tilt. Stock alt ? eh i bet its being pushed to the limits . Quote 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd Link to comment Share on other sites More sharing options...
greenlight00 Posted May 7, 2012 Author Report Share Posted May 7, 2012 The only thing that is stock is the alt. Full tilt I'm around 12.7 volts on both batteries. 14.4 at idle Quote Link to comment Share on other sites More sharing options...
252chevyboyz Posted May 7, 2012 Report Share Posted May 7, 2012 Kranny did make a good point about sanding and wire brushing the grounds. I took the bolts out of my ground location and used the wire brush wheel on a bench grinder and cleaned them up. I also took a flat head that I sharpened on my knife stones and stripped away the paint underneath the head of the bolt then took some Goof Off and Carb Cleaner and cleaned any oily/grimy residue off. The reason I used a "sharpened" flat head was cause I didnt want to scrape any of the paint away outside of that circle so it wouldnt looked all scratched up. @MIke: Did you mean check the voltage coming directly off the Alt while playing full tilt? You are more than likely right about the stock Alt being pushed to its limits -James Quote - 1997 Chevy Tahoe- Big 3 (1/0)- Dual Autocraft Batts- JVC KD-A315 HU- AQ 2200.1D- 18" AQ HDC3- Box w/ Removable Port (6ft^3 @ 36hz & 6.7ft^3 @ 42hz)- 39' 1/0 & 13' 2/0 Flex-A-Prene My Selling Feedback Build Log Link to comment Share on other sites More sharing options...
