Wicks Posted May 4, 2012 Report Share Posted May 4, 2012 Well you pinned down the faulty wire so you just have to keep following it back to where it originates and look for the issue. If you have access to the fuse panel, you could always find an empty slot that has constant battery voltage and run a new (fused) wire to the HU. I would want to track down the faulty issue though. Wires in your dash with faulty voltage readings is not a good thing... If there's a short, or corrosion or something, you'll want to fix it now before it degrades into a real problem. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026 Link to comment Share on other sites More sharing options...
SmallTruk Posted May 4, 2012 Report Share Posted May 4, 2012 if you wanted to avoid having the light work at all you can simply split the remote wire and connect one side to the center pin and one side to the B+ pin. Id do it the other way but this will work too. dafuq? to avoid the switch lighting just don't connect the ground. switches with lights need a ground to power it when on, switches without lights have no ground. Link to comment Share on other sites More sharing options...
rogue Posted May 5, 2012 Report Share Posted May 5, 2012 if you wanted to avoid having the light work at all you can simply split the remote wire and connect one side to the center pin and one side to the B+ pin. Id do it the other way but this will work too. dafuq? to avoid the switch lighting just don't connect the ground. switches with lights need a ground to power it when on, switches without lights have no ground. Um thats just another way to say what I've already said genius. BMW X5 Stealth Build w/ IPAD BMW 325i Rear Deck Digital Designs Build BMW 325i Car PC Touchscreen Bezel Build Link to comment Share on other sites More sharing options...
Crandis16 Posted May 8, 2012 Report Share Posted May 8, 2012 I did the same wiring for the sub in my car, but I didn't like how the light stayed on, even when the LEDs were off. Is there a way to wire the switch to have the LED turn on when the switch is on? My Red zx2 Build Log My Black zx2 Build Log My Red zx2 UBL Link to comment Share on other sites More sharing options...
TheNewbie Posted May 8, 2012 Author Report Share Posted May 8, 2012 D make a new thread sir prob be better but if you hook it up with your ignition wire I'd assume that could work and would turn off when the car turns off.. Could also be very wrong just a suggestion Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes. Link to comment Share on other sites More sharing options...
