TheNewbie Posted May 4, 2012 Report Posted May 4, 2012 I have a switch that I want to use to turn off my bass when needed, it has three prongs assuming one ground one power and one for whatever I want to turn on and off. But icant figure out what one is for what. Also since I want to have this to turn the bass on and off I would simply put the remote wire from the H/U to the switch.. (whatever prong it goes to) and wire in with it a remote wire from the switch to the amp? So both would be together on one prOng. Any help on this would be great pictures below. Just notices this so I'm thinking power is pos next is ground then bronze*** is what I want on and off? Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes.
rogue Posted May 4, 2012 Report Posted May 4, 2012 one pin will be 12v in, one will be ground and the other will be 12v out. BMW X5 Stealth Build w/ IPAD BMW 325i Rear Deck Digital Designs Build BMW 325i Car PC Touchscreen Bezel Build
HatersGonnaHate Posted May 4, 2012 Report Posted May 4, 2012 B+ is one side of the remote, the one with the 3 lines under it is the other side of the remote. The middle one is just for the light bulb in the switch to light up. My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol srp365 - If posting were picking up bitches, I'd be going home single tonight looks like tony montana sneezed in your car.
TheNewbie Posted May 4, 2012 Author Report Posted May 4, 2012 one pin will be 12v in, one will be ground and the other will be 12v out. How can I tell what one is what? Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes.
rogue Posted May 4, 2012 Report Posted May 4, 2012 Ok in order of that new pic Ground, Remote turn on, and then 12v. BMW X5 Stealth Build w/ IPAD BMW 325i Rear Deck Digital Designs Build BMW 325i Car PC Touchscreen Bezel Build
TheNewbie Posted May 4, 2012 Author Report Posted May 4, 2012 B+ is one side of the remote, the one with the 3 lines under it is the other side of the remote. The middle one is just for the light bulb in the switch to light up. Ah great thank you sir. Seems a lot more simple now.To get the light to light up hook the middle to the batt? Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes.
Wicks Posted May 4, 2012 Report Posted May 4, 2012 The downward pointing arrow shape is the Ground symbol (copper colored terminal on the left). +B is your battery voltage (12V). The headlight looking symbol should be your voltage out. .....ninja'd This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
TheNewbie Posted May 4, 2012 Author Report Posted May 4, 2012 The downward pointing arrow shape is the Ground symbol (copper colored terminal on the left). +B is your battery voltage (12V). The headlight looking symbol should be your voltage out. .....ninja'd Light just turned on.. So in terms of what imdoung the 12 out is my remote wire from the H/u? With another remote wire with it going to the amp? Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes.
HatersGonnaHate Posted May 4, 2012 Report Posted May 4, 2012 B+ is one side of the remote, the one with the 3 lines under it is the other side of the remote. The middle one is just for the light bulb in the switch to light up. Ah great thank you sir. Seems a lot more simple now.To get the light to light up hook the middle to the batt? Actually, forget what I said. Wicks is correct. I'm used to running switches with no lights in them. My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol srp365 - If posting were picking up bitches, I'd be going home single tonight looks like tony montana sneezed in your car.
rogue Posted May 4, 2012 Report Posted May 4, 2012 B+ is one side of the remote, the one with the 3 lines under it is the other side of the remote. The middle one is just for the light bulb in the switch to light up. Ah great thank you sir. Seems a lot more simple now.To get the light to light up hook the middle to the batt? ^^^thats not going to work Ok in order of that new pic Ground, Remote turn on, and then 12v. The downward pointing arrow shape is the Ground symbol (copper colored terminal on the left). +B is your battery voltage (12V). The headlight looking symbol should be your voltage out. .....ninja'd This ^^^ is what you must do, the light in the switch will also work properly when you turn the switch on. BMW X5 Stealth Build w/ IPAD BMW 325i Rear Deck Digital Designs Build BMW 325i Car PC Touchscreen Bezel Build
