Well you pinned down the faulty wire so you just have to keep following it back to where it originates and look for the issue.
If you have access to the fuse panel, you could always find an empty slot that has constant battery voltage and run a new (fused) wire to the HU.
I would want to track down the faulty issue though. Wires in your dash with faulty voltage readings is not a good thing...
If there's a short, or corrosion or something, you'll want to fix it now before it degrades into a real problem.
This post sent with 100% recycled electrons.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
500F of Maxwell SuperCaps (soon to be 1000F)
iPadMini2
Dash mounted O-scope
Audison bitOne (Remote DRC MP)
Highs Amp - PPI Art A404
Hertz HSK130 (HSK165 waiting...)
DC Audio DC9.0K
2- DC Audio XL12m2
LEGAL             - 147.3dB @ 41Hz
OUTLAW         - 150.2dB @ 45Hz
OUTLAW         - 145.7dB @ 30Hz
JUNE 2014 SOTM WINNER
2014 COLORADO PEOPLE'S CHOICE WINNER
SOTM BUILD:
http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
if you wanted to avoid having the light work at all you can simply split the remote wire and connect one side to the center pin and one side to the B+ pin.
Id do it the other way but this will work too.
dafuq? to avoid the switch lighting just don't connect the ground. switches with lights need a ground to power it when on, switches without lights have no ground.
Um thats just another way to say what I've already said genius.
I did the same wiring for the sub in my car, but I didn't like how the light stayed on, even when the LEDs were off. Is there a way to wire the switch to have the LED turn on when the switch is on?
D make a new thread sir prob be better but if you hook it up with your ignition wire I'd assume that could work and would turn off when the car turns off.. Could also be very wrong just a suggestion
Check out my build log:
http://www.stevemead...60#entry1958353
Different folks have different strokes.
  • Who's Online   0 Members, 0 Anonymous, 907 Guests (See full list)
