Project "Yoda" 95 toyota corolla
i wouldn't use a seat bolt. on the back part of the rear seat, on my car at least, on the bottom there are 3 U hook's that gets bolted to the car body with 12mm bolts to hold the back part of the seat in place. i used the middle one for my grounds. sand the paint off on the body til its shiny and you're golden.
k thxs man
95 toyota corolla
1.8 dohc
5 speed
system in planing stages right now
well i ma do my ground when i get out of school today....and also with the subs...as of right now i m planning on getting rf p2s but i m open to other stuff just keep in mind that my amps doin 500 at 1 ohm but if anyone has anything they think would be good i m game....right now i want 2 tens but i could do somethen else
95 toyota corolla
1.8 dohc
5 speed
well idk what happened but it seems that my motor is making weird noises and its worrying me so i parked t at my friend shop for us to take alook at it....hopefully its nothing major but we ll see
95 toyota corolla
1.8 dohc
5 speed
turns out it was back firing through an exhaust leak....scared the shit out of me but now i m alot happier to know what it was......i also replaced the tps and map senor to no avail <_< but my buddie/boss says it might be in the computer so i ma go ahead and get one to replace it....but can t do that today so i m prob just gonna do my ground and get that out of the way might even get the amp in there and see if it powers up
95 toyota corolla
1.8 dohc
5 speed
you can fit 2 12's in the trunk no problem. i wouldn't make the box wider than like 36" though cause you might run into problems fitting it through the trunk opening.
does your car have the notorious exhaust manifold crack? mine does. makes it sound so ricey and i hate it. fucking like 5" crack right on the top of the manifold. only way to fix it is to get a new manifold off of ebay or something for like $100
i don t know but u can get a chinese header for ike 50 bucks i think at least i can
95 toyota corolla
1.8 dohc
5 speed
well the passenger side axle seel went out and i bought the seel just need to put it in which i l do tonight but this is what i got done on sunday before that happened
seats out
my ground spot
where it bends it had a sharp edge so i came up with this
put heat shrink over it
all shrunk up
also bought ths because my was broke.....so i painted it black :P
95 toyota corolla
1.8 dohc
5 speed
yeah the chinese ones on ebay. i forget how much they are, $50-60 sounds more accurate.
you can usually see the crack through the exhaust manifold's heat shield, at least for mine. if you open the hood while the car is on, you'll hear a really obvious exhaust leak, if its cracked there.
build looks good so far, i saw that you sanded down the paint on your ground point :P
