has any one done a 00-05 deville build on SMD????
My build
http://www.stevemead...20#entry2018495
Car: 2003 Cadillac DTS
(1) Hifonics Brutus BRZ2400.1
(1)Hifonics Zrx600.4
(1) 1000 watt crunch amp
(1)200 watt boss amp
(2) Pyramid TW46
(4) Infinity Kappa 60.9cs
(1) EV 10 inch
(2) XSpower 1200
(4) Pyramid TW18
box tuned at 32 Hz
(2) DC level 3
I hope you know what you are doing, these Cadillacs are super sensitive bro. One fuck up and you will have electrical problems out the ass. I believe you have the battery underneath the rear seat like me correct?
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
yhea their under the rear seat and i know that their super sensitive because i just had a electrical problem... i had to run every wire in the car pain in the ass
My build
(2) Pyramid TW46
(1) EV 10 inch
(2) XSpower 1200
(4) Pyramid TW18
box tuned at 32 Hz
(2) DC level 3
I didn't do my install myself but luckily the shop I went to the owner had a 97 STS so he knew what adapter to get and what not.
I'm not sure if it's because they used CCA wiring and I don't believe they actually sanded down the back bracing of the rear seat before grounding my amp but I do get dimming of my lights when its up loud at night, plus RPM drops at idle and its only 500rms. Where did you ground the amps at or here do you plan on grounding them? Also can you post up some pics when you do the Big 3?
I'm tuned in, I love my Caddy!
2015 Mazda 6
ok ill take pic of were is my ground and the big 3 has been killer for me because have not done it lol i was told the it was not needed since caddys run so much power but ... i do and dimming for the lights i only got a little with the 3 CVRs ill try to fix up a short video showing the subs off before i sell them on sunday
My build
(2) Pyramid TW46
(1) EV 10 inch
(2) XSpower 1200
(4) Pyramid TW18
box tuned at 32 Hz
(2) DC level 3
i will post some new pic today :drink40:
My build
(2) Pyramid TW46
(1) EV 10 inch
(2) XSpower 1200
(4) Pyramid TW18
box tuned at 32 Hz
(2) DC level 3
Thanks, I'm guessing its my wires and the amp ground not being ideal. Too lazy to fix it. Normal idle is 650 and I get drops of about 100 or so and dimming of the headlights past 25/35 on my deck. I used to even get dimming when driving on certain songs when I was still running my Bose tweets/center 3.5" on the dash, once I stopped running those and now run my RF comps (off the HU) I don't get that anymore unless its a hella punchy bass line.
2015 Mazda 6
trac button and volt meter !
My build
(2) Pyramid TW46
(1) EV 10 inch
(2) XSpower 1200
(4) Pyramid TW18
box tuned at 32 Hz
(2) DC level 3
this is the piece that will hold the cross overs and switches
My build
(2) Pyramid TW46
(1) EV 10 inch
(2) XSpower 1200
(4) Pyramid TW18
box tuned at 32 Hz
(2) DC level 3
DSC01508.jpgM
my boys G35x
My build
(2) Pyramid TW46
(1) EV 10 inch
(2) XSpower 1200
(4) Pyramid TW18
box tuned at 32 Hz
(2) DC level 3
  • Who's Online   0 Members, 0 Anonymous, 555 Guests (See full list)
