Amp is still in great working conditions. 10/10 mechanically. There is rub marks on it due to the sub box rubbing on it, nothing to major and does not effect any functions of the amp.
225$ shipped to lower 48 states conus
The rubbing on the amp
Power Specifications - Full Range Channels
RMS Power @ 4 ohms 120 watts x 4 channels
RMS Power @ 2 ohms 160 watts x 4 channels
RMS Power @ 1 ohm N/A
Bridged RMS Power 320 watts x 2 channels
Peak Power Output N/A
Amplifier Specifications
Amplifier Class AB
Number of Channels 4
Total Peak Power Output N/A
Total RMS Power Output 650 watts
Maximum Input Gauge Size 4 AWG
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power <1%
Speaker Level Inputs Yes
Preamp Outputs No
Built-in Crossover Low-pass (LP)
High-pass (HP)
Full (AP)
High-Pass Crossover Frequency 50 - 200 Hz
Low-Pass Crossover Frequency 50 - 200 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio 95 dB
Channel Separation N/A
Bass Boost 0 - 18 dB
Fan Cooled No
Fuse Rating 80A x 1
CEA-2006 Compliant Yes
Edited by KenC210
