Hello not sure if this is the right place to post a HID question but here it goes. I have a 2005 Pontiac Montana and I got some HID Xenon 9004 for my headlight and 880 for the fogs. Installed them today and the fogs works great but having problems with my headlights.
I used everything that came with the kit, relay harness installed .
First the passenger side headlight would turn on and thorn off a few second later but the driver side would stay on.
I Google my problem and many places said to try and switch the bulbs from driver to pass- pass to driver.
I did just that and now my problem is that the driver and pass stay on but the driver side flickers and I could hear a tick coming from the front. It also tick in my front speakers. My fronts are Infinity Kappa running off a old school Earthquake PH120.2, but the tick wasn't there before I installed the HID today.
Any could help me out it would be great.
Thanks
First thing I would do is install a relay for each light ballast ... and run a larger cable from your batteries to your relays ... and make sure that your grounds are as solid as your Car audio system ... I am in the process of doing this to mine ...
Edited by Cablguy184
The relay looks like its a double relay and and the ground I sanded and removed the paint, it to the metal. Here are a few pictures it may be hard to see the ground.
relay
drivers ground
pass ground
ok jr u have a bad ballast.. i had the same problem with my passenger headlight, and when i got a new ballast, (i was bitching to the guy i bought them from) i installed it and havent had a problem since
thanks I called the guy today and I'm going Monday and the installer is going to have a look at them. Hopefully he could figure something out.
and also if u get the AC ballasts they work alot better then the DC ones, the DC ones cause the bulbs to flicker... and the AC ballasts have the built in stabilizer and the bulb will last longer
  • 3 weeks later...
Are your HID relays powered by your light harness wires or did you run a direct power and ground and only use your harness wire as a switch wire ??
Awesome !!!
Thanks
This is the most you can do.....but still there are going to flicker...this is not the very solution...Using better quality HIDs is always better..!!
Edited by adinojones
Sure, we can sit and fantasize all we want about how things are going to be different one day, but this is today; and today sucks.
