Names_jeff Posted May 12, 2012 Report Share Posted May 12, 2012 Ok, so im a dumbass and hook up my batt up wrong with pos and neg switched ( installed an xs batt today and the pos and neg were opposite of my stock battery). this lead to a spark and now when i turn my car on, my headunit will not turn on! any ideas why? did i blow a fuze or did i fry my deck? -thanks Quote Link to comment Share on other sites More sharing options...
01ExSport Posted May 13, 2012 Report Share Posted May 13, 2012 When you unhook your car battery with an Alpine, on mine at least, you have to hit power or standby for it to turn on. Hopefully it'll be the same for you. Quote Link to comment Share on other sites More sharing options...
Names_jeff Posted May 13, 2012 Author Report Share Posted May 13, 2012 When you unhook your car battery with an Alpine, on mine at least, you have to hit power or standby for it to turn on. Hopefully it'll be the same for you. yes. i know this but ive held down the power button and nothing happened. ive messed with it for a while to and just nothing. Quote Link to comment Share on other sites More sharing options...
Guest Posted May 13, 2012 Report Share Posted May 13, 2012 check fuses under the hood labeled "stereo" or something like that. check onboard fuse on headunit. Quote Link to comment Share on other sites More sharing options...
Names_jeff Posted May 13, 2012 Author Report Share Posted May 13, 2012 check fuses under the hood labeled "stereo" or something like that. check onboard fuse on headunit. i'll have to check this out, thanks Quote Link to comment Share on other sites More sharing options...
01ExSport Posted May 13, 2012 Report Share Posted May 13, 2012 Also, I'd whip out the multimeter and see if you're getting power to constant and acc if the fuses are a no-go. You'd more than likely see a popped one in the relay though. Quote Link to comment Share on other sites More sharing options...
Names_jeff Posted May 13, 2012 Author Report Share Posted May 13, 2012 Also, I'd whip out the multimeter and see if you're getting power to constant and acc if the fuses are a no-go. You'd more than likely see a popped one in the relay though. alright sounds good. ill try this. Quote Link to comment Share on other sites More sharing options...
Names_jeff Posted May 13, 2012 Author Report Share Posted May 13, 2012 Checked the fuzes in the hood. There all good. Is there a fuze behind the deck? Or an inline fuze or something. With a deck like this you would think there would be a protect or something instead of just frying it. Any aideas? Quote Link to comment Share on other sites More sharing options...
01ExSport Posted May 13, 2012 Report Share Posted May 13, 2012 There should be mostly likely a 10A fuse on the back on the H/Uitself. Quote Link to comment Share on other sites More sharing options...
Robert8252 Posted May 13, 2012 Report Share Posted May 13, 2012 Also under or on the side of your dash you should have fusing which is where the fuse would be for the radio, cluster, dome lights, etc... Quote 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff Link to comment Share on other sites More sharing options...
