KC_Burban Posted May 18, 2012 Report Share Posted May 18, 2012 (edited) What is your electrical like? You are for sure going to need to do the big three and I would say at least a Knetik HC600 in the back. There tough little amps just watch your voltage. Edit: Spelling Edited May 18, 2012 by KC_Burban Quote 1998 GMC Suburban 1500 20" Southern Comfort rims... too small ): HU - Kenwood KDC -x396 Link to comment Share on other sites More sharing options...
Guest Posted May 18, 2012 Report Share Posted May 18, 2012 what these people dont realize is, that every system is different. you put one persons subs at .5 at the amp, it can work fine because of impedance rise. put another guys subs at .5 on it, and the amp can fuck up. dont risk it. if you do, dont complain that it broke if it does Quote Link to comment Share on other sites More sharing options...
Mario928 Posted May 18, 2012 Report Share Posted May 18, 2012 Just because you saw a guy on you tube running is amp at .5 doesn't mean its ok to run at .5 ohms. Quote Build Under Construction Head Unit = Kenwood DDX514 Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4 Battery = XS D3400 Wires = Kicker RCA's, 0 Gauge street wire and Stinger Mids and Highs = Stock Sub= Kicker L7 12" Alternator = 220 Mechman Sound Deadner= Fatmat and Stinger Road Kill Link to comment Share on other sites More sharing options...
caspers bass Posted May 18, 2012 Author Report Share Posted May 18, 2012 i got did big 3 no batteries as of now and i know i really dont want to run at .5 i just cant find a decent at amp to run at 2 ohms that will give me the power i want which is why this is skechtin me out lol Quote Link to comment Share on other sites More sharing options...
caspers bass Posted May 18, 2012 Author Report Share Posted May 18, 2012 Just because you saw a guy on you tube running is amp at .5 doesn't mean its ok to run at .5 ohms. fyi didnt see someone running this at .5 im looking for any amp in my price range that will give me the power i want at .5 or 2, so ya hop off Quote Link to comment Share on other sites More sharing options...
KC_Burban Posted May 18, 2012 Report Share Posted May 18, 2012 I ran an aq1200 .5 ohm daily but i had the electrical to back it up. I had an upgraded 220 amp alt and two HC600s in the rear with 2 runs of zero gauge. I so little too know voltage drop while driving and a little bit more drop when just idling. So if you are planning on keeping this setup for a while I would just get a second batt or two and call it good. Quote 1998 GMC Suburban 1500 20" Southern Comfort rims... too small ): HU - Kenwood KDC -x396 Link to comment Share on other sites More sharing options...
Watch the bass Posted May 18, 2012 Report Share Posted May 18, 2012 What Ohm´s does he get with boxrise? Quote "in the abundance of water, the fool is thirsty" Bob Marley Link to comment Share on other sites More sharing options...
caspers bass Posted May 18, 2012 Author Report Share Posted May 18, 2012 I ran an aq1200 .5 ohm daily but i had the electrical to back it up. I had an upgraded 220 amp alt and two HC600s in the rear with 2 runs of zero gauge. I so little too know voltage drop while driving and a little bit more drop when just idling. So if you are planning on keeping this setup for a while I would just get a second batt or two and call it good. i got stock atl atm and only 1 run of 0 gauge but this is still sketchin me out lol so with stock alt and 2 batts my volt should stay decent without to much drop? Quote Link to comment Share on other sites More sharing options...
KC_Burban Posted May 18, 2012 Report Share Posted May 18, 2012 Id say so but not for sure there are way to many variables. Just because it worked for me does not necessarily mean it will work for you. But id say if you were to get a couple more batts and add another run you would be ok. But by the time you spend money for all of that you could get an AQ2200. Quote 1998 GMC Suburban 1500 20" Southern Comfort rims... too small ): HU - Kenwood KDC -x396 Link to comment Share on other sites More sharing options...
caspers bass Posted May 18, 2012 Author Report Share Posted May 18, 2012 ya i started thinkin that its just i hate tryin to save up lol but i guess i got to, guess i gotta keep runnin my ap 1500-FAIL for awhile lol oh well gotta pay to play i guess Quote Link to comment Share on other sites More sharing options...
