caspers bass Posted May 14, 2012 Report Posted May 14, 2012 quick question with a aq 1200 run at .5 for a daily setup or not cause if not im going to go with a diffrent amp Quote
TheNewbie Posted May 14, 2012 Report Posted May 14, 2012 Why risk running it at .5 get a amp that pushes the power at 1 ohm... Quote Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes.
Toby Ratcliffe Posted May 14, 2012 Report Posted May 14, 2012 It is not .5 ohm stable. It may, or may not work in your situation, but you won't know until you have it hooked up. Why do you need .5 ohms? Did you order two dual 2 ohm subs? Quote
bobobass Posted May 15, 2012 Report Posted May 15, 2012 Is there any reason you want to run it at .5 ohms? Quote 2000 Subaru outback 2.5l Head Unit: Pioneer deh 4300ub front stage: tbd subwoofer: Stock Fi Q 18" amp: Audio que 1200d
caspers bass Posted May 15, 2012 Author Report Posted May 15, 2012 well i i ordererd a hdc3 18 and i thought i ordered the d2 but i guess i did the d1 Quote
Toby Ratcliffe Posted May 15, 2012 Report Posted May 15, 2012 Get the AQ2200 if you can afford it and run it at 2 ohms. You can upgrade to a second 18 and still have enough power for both. Quote
bobobass Posted May 15, 2012 Report Posted May 15, 2012 Check the invoice, if it says you ordered the d2 you could sent the sub back for the d2. Quote 2000 Subaru outback 2.5l Head Unit: Pioneer deh 4300ub front stage: tbd subwoofer: Stock Fi Q 18" amp: Audio que 1200d
caspers bass Posted May 15, 2012 Author Report Posted May 15, 2012 well the 2.2k is lil more than i can spend right now and i dont plan on gettin another 18 for a few months so basically just tryin to find something to give around 2k or so but dont got money to buy amps to wire down to 2 ohm atm to power it so i need amp that does .5. and i did i hit d1 like a moron lol oh well i guess Quote
aleroking Posted May 15, 2012 Report Posted May 15, 2012 ive seen plenty be ran at .5 Quote 2 fi btl 18s on 2 crescendo 3500s walled in a 2dr 2000 alero build log http://www.stevemeadedesigns.com/board/topic/141663-2-walled-btls-18-on-7k-in-a-2000-2dr-alero/
caspers bass Posted May 18, 2012 Author Report Posted May 18, 2012 ive seen plenty be ran at .5 so your saying i can run this at .5 for daily with little to no problems? need to know cause if not ill wait lil more and get a crescendo 2k just need amp right now Quote
