help with KINETIK HC600 pt.2
so i just put in a kinetik hc 600 in the back..... had some problems with it blowing fuses (80) amps.... now i have put in 150 anl fuses in front after batt then 150 anl befor the kinetik then a 150 anl befor the amp, so the problem im haveing now is that its all work good and not blowing fuses but is now hiting at like 3/4 loud as it was befor. not sure whats going on with it now , someone know whats going on?
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
ummm... want to give a lot more info there chief? amps, wire size, fuse holders used, etc. what fuse of the 3 was blowing? when/how did it blow?
do you own a DMM? check voltage going into the amp.
its 4 ga cadance comp wire, 130amp stock alt , new batt in front but a cheap 800 amps advaned auto parts batt , 150anl fuses/holders are bullz audio, planet audio AP 1500D, 2 -12''
re audio RS dvc 2ohm ran at 2 ohm.. so 750 -800rms to them. so i had them same fuse set up with dblink 80amps and was blowing them fast like 2 min... 1st 1 was amp to kinetik then next day the fuse befor the kinetik... never blew the frnt fuse..
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
  • Who's Online   0 Members, 0 Anonymous, 933 Guests (See full list)
