I scored a Kinetik HC2000 today. Essentially new in box used for a month. I plan on installing it soon but I am worried abut it. A little background on the car. 95 Impala, Interstate Megatron Plus Dual Terminal 78 Group Size up front, 800cca, 1000ca battery. I plan on adding the HC2000 in the turnk with 1/0 wiring and grounds. I am concerned that there is something wrong with the battery, but it might just be me? I got it from a friend and I tested it at work today with our ED-18 hand held Interstate Battery Tester. It had 12.6 volts and 300ca's? I thought these things were supposed to have like 1500 cranking amps? I 12 volt 2 amp charged it for about 20 minutes which brought the voltage up to 12.8, (surface charge) and it tested at 500ca's. I am hoping the tester at work just doesnt know how to test this type of battery. Is there anything else I can do to test/check the integrity of this battery? Thanks in advance.
1986 Buick Regal Grand National(1) RFD2210 1.25 CUFT @ 38hz Slot PortRFX-9420, Punch 4080dsm, Power 250m22003 Mercury Marauder - Dark Blue PearlDDX-419, T600-4, T2652-S, HPC2205
(Currently Working on Designing an Enclosure)
I understand this. I am concerned with the crank amps, the voltage looks normal.
  • Who's Online   0 Members, 0 Anonymous, 1078 Guests (See full list)
