biohazardbill Posted May 19, 2012 Report Posted May 19, 2012 Question, it has been a while so cant remember how this works. If I have an amp that is rated at 100w @ 4 ohm and I put a 4 ohm speaker that speaker will see 100w right? So now same 100w but i put 2 8 ohm speakers in parallel (4ohm load) amp still puts out 100w but each speaker only uses 50w right? That being said if an amp is rated at 100w @ 4ohm and 200w @ 2 ohm then if I put 2 4 ohm speakers in parallel (2ohm load) then each 4 ohm speaker would see 100 watts correct? The speaker line has 200w on it but due to the ohm load of each speaker each speaker would only see 100w.
Watch the bass Posted May 19, 2012 Report Posted May 19, 2012 Correct "in the abundance of water, the fool is thirsty" Bob Marley
