Checking Ohm load on strapped amps?
How do I check the final ohm load or even the ohm load to each woofer when my amps are strapped? I am using a DMM, I messed around with it last night but I was not sure what speaker outputs to check as they are wired differently when strapped. ie all the negitives are together and you use the positives on one amp for the negitives. I got a bit confised lol Thanks.
Heres how I wired them.
Wire a pos from one coil to a negative of the other coil. Do that for both subs.
Wire the two remaining positives to the positive of the master amp.
Wire the two remaining negatives to the positive of the slave amp.
Connect the two ground terminals of the master amp to the two ground terminals of the slave amp.
  • Who's Online   0 Members, 0 Anonymous, 2310 Guests (See full list)
