Battery Choice, and wiring Questions.
Let me start with what I have, My truck is a 1996 Ford Explorer Eddie Bauer Edition, which means I have the 130amp Alternator.
I am looking for a cheaper, but not a garbage Battery to support the system I am putting in my truck. But after looking online at some battery prices, and seeing most well over $200, I just gave up, There was no way I can afford that. I have set myself a budget of at MAXIMUM of $200, including tax, and shipping(If I need to buy online). My local shop suggested Optima, but it is out of my price range @ $240, or a High Output Interstate Battery, which only costs $150, but I have never had experience with Interstate battery's.
I am honestly open to anything. My system is not SPL, I will be running 2 12inch subs, with a 500watt RMS amp, and 4 door speakers with 200watt RMS.
I already plan on doing the "Big 3", so I know I can get the most out of my system and alternator.
I plan on running some 4 gauge wire, unless somebody can explain why anything bigger would help, considering my system does not draw enough power to need 2, or 0 gauge wire. Plus 2, or 0 gauge is much more expensive, then 4 gauge.
My third and final question is about battery terminals. I know it is much cheaper to just hook every thing up with ring terminals, bit im my honest opinion, it looks horrible, and I would like to go for a clean look. so what are some CHEAP, but not junk battery terminals I can use?
Any input would be great, much thanks, Harold.
1996 Ford Explorer Eddie Bauer V8 AWD
So far with the Ford/JBL Stock Stereo system, Alpine System coming soon.
i would suggest battery terminals and wiring from knukonceptz. You honestly won't need an upgraded battery with the power you're running. the big 3 should be plenty.
Audio Build
Ride: 2002 Chevy Blazer 4 door
Head Unit: Pioneer deh-80prs
Subs: 4 DC Level 3 15's in a 4th order wall designed by Trent Choate and Jeff Smith
Subs Amp: AQ 3500.1 at wired at .5 (soon to be 2)
Mids/Highs Amp: Skar 85.4
Mids/Highs: Skar components
Electrical: Mechman 270 amp alt, 2 runs of Knu 0 gauge, XS Power d3400, 2 Deka Group 9a31
Build log : http://www.stevemeadedesigns.com/board/topic/167658-indianabasshead-blazer-dc-audio-4th-order-wall-build/
Perfomance Build
2003 Nissan 350z
Greddy Twin Turbo, 3" Test pipes with Borla high-flow cats, Crawford Performance Plenum, Greddy E-manage Ultimate ECU
Exedy Racing Clutch, Built Motor by Racing Innovations
Greddy Over-fender aero kit (1 of 20 ever made), 19" Racing Hart r5 pro wheels
466rwhp
Bike
2008 Midnight Blue Kawasaki ZX-14
Stretched 8" and lowered, Brocks Sidewinder exhaust, Power Commander 5
I appreciate the reply. With my battery, it is a Walmart Battery, and I want to replace it anyway, one of the cells is dying, and it is just above 12 volts, so it is going out. I will be sure to check out Knukonceptz for some terminals.
what amp are you running?? and i would check out the knu CCA wire it is 0 guage but only $2 a foot so you could do the big 3 with it and run it to your amp so you could upgrade in the future. just a option. eather way i would do the big 3 with 0.
2003 VW Jetta Wagon AA Mayhem 15's Flatline BA2 2 XS D3100's in rear Shuriken BT80 under hood
Mike Singer 250A SHCA and KnuKonceptz wire Big 4+
AQ / Dayton pro mids+monsoon tweets
My Build : http://www.stevemead...35#entry1989435
honestly i would rather have OFC 4gauge wire instead of 0g CCA.. cca wire totally sucks in my book
but UNLESS you do plan on upgrading in the future.. the 0g is complete overkill and kind of a waste of money
and there is OFC 0g on ebay for cheaper than 2bux a foot.. OFC is ALWAYS better
The 2 amps I am running are an Alpine MRP-M500, and a much older Sony XM-4045, the Sony I don't think needs 4 Gauge to go to it, I was considering just running 8 gauge.But I am for sure running 4 gauge to the Alpine amp.
As for the wire, my local shop has some high strand wire for $1.39 a foot. I figure I should just go with that, that way I don't have to wait, and pay for shipping.
no need to waste wire and run 2 positive wires..
alpine m500 and small amp.. single ofc run of 4g front to back..and use a distrobution block and do your 8g to the sony and 4g or 8g to the alpine
single 4g run to distobution block..simple as pie
yeah in that case just do that and go to autozone and get a battery with a 3 year warrinty so if you burn it up you can swap it out. also i know cca is not then best but its a option. but if you have the $ for ofc then its a no brainer.
Thanks for the info, I guess just running one larger gauge and then splitting it in to the two amps never came to mind. It makes a lot of sense. I think most of my problem is that I am over thinking everything, and thinking my system is bigger then it actually is. I get pretty hyped up when I watch Youtube videos with guys with 15's and 18's and have well over 6000 watts of power. I just want my system to be headache free , and sound good. Not buying a HO battery will help me install everything a lot quicker.
  • Who's Online   0 Members, 0 Anonymous, 2208 Guests (See full list)
