GTPT Posted May 22, 2012 Report Posted May 22, 2012 Alright I have 2 Type R 1043D subs they are 4 ohm DVC - 600 watts RMS each I also have 2 Soundstream pca1000d amps (500x1 @ 4 ohms) (800x1 @ 2 ohms) (1000x1 @ 1 ohm) Should I run both subs of one amp, or One sub on each amp? Currently in a single ported enclosure.
Bump4life Posted May 22, 2012 Report Posted May 22, 2012 1 sub each amp @ 2ohms. make sure your not clipping! and dont forget to gain match!!! Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
CleanSierra Posted May 22, 2012 Report Posted May 22, 2012 1 sub each amp @ 2ohms. make sure your not clipping! You'll have to gain match the 2 amps if you run two different amps for subs in the same enclosure. I'd do that too though, run at 2 ohms from two separate amps. Im not the one you want to try to troll. Just a fyi for you.
Bump4life Posted May 22, 2012 Report Posted May 22, 2012 ninjad edited ahaha Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
Guest Posted May 22, 2012 Report Posted May 22, 2012 someone needs to tell OP how to gain match correctly. otherwise whats the point in telling him to do something he doesn't know about?
Bump4life Posted May 22, 2012 Report Posted May 22, 2012 someone needs to tell OP how to gain match correctly. otherwise whats the point in telling him to do something he doesn't know about? maybe you could? i gotta go mow the lawn. ahah Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
GTPT Posted May 22, 2012 Author Report Posted May 22, 2012 I used the DD-1 on the amps. Both amps are set the same. and thanks for the info. Thats how I have them set 1 amp on 1 sub @ 2 ohms
