I have 2 12" Audiobahn AW1200Q http://www.crutchfield.com/S-DLMNBAuBTq0/p_037AW1200Q/Audiobahn-AW1200Q.html?tab=features_and_specs#details-tab and A Crunch 1600watt amp http://www.audioallies.com/GetItem.asp?Item=GP1600.1. Thinking my equipment was bad.... I went to the audio shop and he told me the equipment was still good.(Wiring issues overheating my Amp. I want to know whats the best way to wire these 4ohm speakers to get the best power? Im still a rookie in the Car audio world and I am looking to do this stuff on my own to save more money. HELP PLEASE!!!!
So this set up will be able to work at a 1 ohm load??? Again Im new to this. There are four terminals on each side of both speakers. Do I run the speaker wire to on the outside terminal on positive and negative???
Yes,
does not matter witch side of terminals you use.
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
One more Question... On the amp it also has 2 positive and 2 negative terminals.... Im guessing that it matters where the positive and negative cable go.
Edited by Nipsy06
I was told that amp is not 1ohm so hoe do I wire it in series???
says who? it is 1 ohm stable
