08 Nissan Sentra SE-R Spec V Build (Pure Trunk)
Well I thought I would start a build log as I have never done one before. My old setup was 1 15 inch Fi BTL on a aq2200d with stock electrical. It wasn't enough. So I have decided to go with the loudest reasonable set-up I can get in my sentra without going crazy and cutting out my rear trunk brace to make a wall. Here is what's going in it:
2x 12inch AA Mayhem's (D1)
AQ3500D.1 Amplifier
Box is being built by Marcotheclepto. (specs around 5.5 Cubic Ft Gross, Tuned to 32Hz)
Pioneer AVH-P4400BT Touchscreen Head Unit
Polk Audio DB5251 5.25in Component Speaker System
Pioneer 5500T 2 Channel Amp (125W x2 @ 4 Ohms)
270 Amp DC Power Alternator
XS Power D3400 Battery (Starter)
XS Power D3100 Battery (Trunk)
Over 75ft of 0 Gauge (100% Copper)
Well here is what I have done so far, more to come:
Head Unit Install:
Polk Audio Components Install:
Went through 3 hole saws cutting a hole for wiring to the door speaker on the left side. Took one on the right... go figure.
Flush Mounted Tweeter:
Also got the alternator installed today... It was a pain getting to the pulley tensioner on my car. Had to go to my friends shop to use a lift. If only Nissan would have given me about 5mm more clearance...
Sexy...
K&N Intake in the mail today!
Yeah, I kind of regretted buying the amp right after I did. I also didn't know how far I was going to go with my electrical when I purchased alot of the things I did. What amp would you recommend that could be had for around 700 shipped used?
its a 300w rms BASH amp. Not much but gets the job done. Sub models flat down to 21Hz. Sounds like it too :P
I've got 500wrms in my car and 1500wrms in my room lol, I would like it to be the other way around but I don't want to sacrifice my room system for my car system right now. In time I will build on my car system.
I've got 2 of these
DC 5k, would be my first choice, but it'd be hard to find one for 700. Crescendo 5500, not sure of the pricepoint. Sundown 4500, way expensive.
First, I would try to move that AQ, OR buy a second one.
SMD Super Seller
My Feedback Thread
