Alright, I have the system in my sig. My system, subs as well as components are playing back all of the noises my vehicle makes, including the turn signal click. The only place I see that can affect both components and subs would be the ground, which is my vehicle chassis. Help.
Edited by littleitaly1990
A vitrolic, megalomaniacal sadistic psychopath.
is your power wire ran next to your signal cable?
some people get that problem and get feedback noise. my power wire and RCAs chill right next to each other and i get NO feedback noise.
Edited by Chode69
NoFearX18 said:
trainman0978 said:
+1, you gotta make sure that ur grounds are good, and make sure that the wires on the alt is good to. And if the noise still countinues then you either have a bad head unit or the alt is making the noise. I hade the same problem and done everything to get rid of it but no luck. Then one day I decided to change my head unit and it worked. I was using pioneer for the hd and I was told that they where known for doing that. So good luck!
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 hertz high energy 6.5s comps
4 stock ad244 alts
6 g31s batts
8 runs 0ga
  • Who's Online   1 Member, 0 Anonymous, 1989 Guests (See full list)
