Kikazz's 1997 Dodge Dakota Club Cab SQ Build *Updated!!!*
here are the pics i took of the amp rack:
you need to get back over here so we can finish those spheres. :)
I know! U think sometime during the week I could come down?
I've got some big plans for this in the spring if I can get the cash for it. ;)
I got some y adapters finally but they suck and will definitely get replaced. It helped the sound tho.
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
  • 1 month later...
Ok guys. Ive been thinking hard about this lately. This box sounds like shit and im tired of the rattles. More and more keep coming up. So my idea was to make a switch. Trade the 18 for a nice 15 or 12 like the Q or other of this area. More sq oriented. Im looking to trade my brz1700 and cash for a ct 1400 too. Id like part of my back seat back. So box on 2/3 of it behind driver seat most likely. Id like to get some deadener and better speakers. But everyone please give me ideas on possible subs and speakers. Hoping to get an agm and redo the wiring with skyhigh. Lemme know what u guys think.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
bump for some thoughts on ^^^
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
  • 3 months later...
Rebuild is underway. This will focus on a mostly active 3way SQ setup. interior is stripped ATM. RCAs, Remote, and Bass Knob control were routed down the transmission hump and flattened and then ran down the middle of the truck. all speaker wire ran and routed to passenger side of the truck. will be getting some foil lined ultra touch padding to replace stock padding. felt will probably coat all panels to deaden. the goal is a 3-way active minus the tweeters with minimal processing.
Final Equipment list:
Tweeters(if used)- Rockford Fosgate Power Series Silk Domes
should do pretty well in comps as this is what a good friend of mine ran and competed with for a while.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
  • 3 months later...
Here you go guys. Build is finishing up. Needs to be tuned, time aligned, RTA ran on it, and metered. But the build is mostly done. It might be a while but things left to do are- Make a beauty panel to cover amps if needed, build a new box, put interior panels back in, put the 4" in and hook up wires that are ran.
Build products to this point:
Sky High Car Audio (Fuse Block w/ 175A fuse, 4ga OFC, 12ga OFC, and 16 ga CCA for Power/Ground, Sub wiring and from amp to crossovers, and speaker wiring that is ran but not hooked up yet)
Kicker (Fuse Block and 200A fuse under hood, 1/0 Hyper Flex Silver Tinned OFC for main run of power and ground)
Rockford Fosgate (2 of 1 1/0 in and 2 1/0 or 4ga out distribution blocks)
MB Quart Reference Series 2 Way Passive Crossovers
JL G6600 six channel amp
Hifonics Brutus BRZ1700.1D @ 2 Ohms
Alpine CDE-147BT Headunit
Hertz Hi-Energy HX300.4D 12" dual 4 ohm
Silver Flute 6.5"
Alpine Tweets
Insulmax Cellulose Insulation
Ultra Touch Denim Insulation with Radiant Heat Barrier
Onto the progress.
First thing was to gut the truck
Running wires
Rcas down middle, speaker down pass side, power under truck driver side.
whats going in the front doors for midbass/midrange
20140305_110617_zpssjbts4sq.jpg20140305_110319_zpsf4xbrv2h.jpg20140305_110312_zpsofyqcxdh.jpg
The Headunit
This was an after the fact thing. i got a spool of SHCA 16 ga in and decided i wanted everything matching. ran wires for 3 way.
This is packed into that panel since it was just a wide open panel after i pulled the rears out. stuff full and it deadened it quite a bit both road noise and hollow sounding. it also is good insulation to keep truck cooler.
20140604_211041_zpssqcup557.jpg20140604_201645_zpsihcjt6vl.jpg20140604_211052_zpsqbqzmxhd.jpg20140604_222630_zpsbtikrhnj.jpg20140605_142510_zpsc2hjlsgm.jpg
Knock test to show the difference. they are quite solid now too.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Radiant barrier/insulated floor pad.
starting on the amp racks. we had them cut but never got them installed.
20140709_194249_zpsgirhotnf.jpg20140709_194454_zps6wmkxmzh.jpg20140710_113323_zpscejr9vdx.jpg
power and ground layout on the sub amp side of things.
Speaker amp layout. cant run active on this setup currently so x overs are being used.
20140710_114625_zpskqxgjacn.jpg20140710_194540_zpspfdefdqw.jpg20140710_194545_zpstkc50kvv.jpg
bit of a mess
the sub. plans are to build a box with a window to show off the beautiful motor of this baby.
20140711_165946_zpsqqigainj.jpg20140711_170026_zpsdavxkawt.jpg20140711_170237_zpsghjpqihi.jpg20140712_163756_zps3mjqgcop.jpg20140712_164105_zpsiqbl4qbz.jpg
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
  • Who's Online   0 Members, 0 Anonymous, 2990 Guests (See full list)
