2 AQ HDC3 18's in my 99 Tahoe **LOT'S OF PICS**
She so damn lazy!!
~Team Nussiance~
Head Unit: Sony MEX-BT38UW
Amplifier: 1 AQ2200d for break in period
Subwoofers: 2 AQ HDC3 18's
Mids and Highs: 1 pair of AQ PA-6.5's and 1 pair of AQ PA Supertweets
Scores: 148.1db @47hz
146db- Dash
143.8db- Headrest
Both on music
I wouldn't use 45s..just a. V on back wall pointing towards port opening..an wooden dowels don't hold bro I took mine out and use allthread.flush mount double baffle should be good..what power are you using
How wide and how long do I make the V? My port is 10" wide and there's 16" between the port and the back wall.
~Team Nussiance~
146db- Dash
143.8db- Headrest
Both on music
i think mine is 5by5by5
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
I think I'm going to do mine 8"wide by 6"long. It shouldn't effect tuning right?
~Team Nussiance~
146db- Dash
143.8db- Headrest
Both on music
old pic an new pic can you see the v..also i dont think it will change tunng it directs airflow out of port..oh and cut the point off the v so its like 1inch flat at tip.thats been proven to help
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Sounds good man. And it wouldn't hurt to put 45's in the other 4 corners would it?
~Team Nussiance~
146db- Dash
143.8db- Headrest
Both on music
45's have been shown to hurt numbers more often than they help...best case scenario they add some extra bracing for the corners but youve built your box well enough you shouldnt have a problem with that
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
No shit? I had no idea. Well i'll just stick with the V then.
~Team Nussiance~
146db- Dash
143.8db- Headrest
Both on music
Well I can't tell you how excited I am about this but my rear view mirror pretty much fell apart today! The bass dropped and so did the mirror!!! FTMFW
~Team Nussiance~
146db- Dash
143.8db- Headrest
Both on music
Nice! lol good shit man.. anytime frame for having this beast metered?
power: dd m4
