I've changed my setup a lot lately but I want to do a 4 12 xfl build. Its goin in a chevy s10 id like it to be as close to a wall as possible, but not planning on building straight in the car soo not possible I guess. For now I'm gunna use a brutus 2000d at .5 ohm. But guna eventually do 2 2000ds strapped at 2ohms. My max dimensions 36" tall, 40"across, and 15" deep..any ideas? Anyone ever do a wall in an s10 ??
That leaves you with around 10 cubes assuming you use 3/4" MDF, I suppose it should work fine just make your port properly. I haven't done any audio in an s10 but I don't see how it would be tougher than any other build.
I'm gonna hate
Those xfls will be happy around 2.25 cu ft each. tune low if your doing a ground pounder set up, you will be VERY happy.
C.A.R. AUDIO
Faist Audio Concepts F.A.C.
96 Escort wagon Murdered out (redneck style)
Eclipse HU, CDT classic Components
ED Nine.2, Hifonics 1608d (borrowed)
2 Powerbass M 15"s 6 cubes tuned to 30 hz
2005 State record holder 0-600 Consumer 143.7 USACi Kick (1 Soundstream SPL15, JL e1200)
2009 3rd Loudest 0-1000 Trunk In Iowa USACi 145.00 kick. (4 Powerbass PS-10's US AMPS MD3D)
146.2db Unofficial. 6-ps-10's MD3D. Personal best 150.9DB 4 Powerbass M-15Ds. American Bass VFL150.1 at .5 ohm
2010 Usaci 0-1000 mod Iowa state record holder 149.4DB
Check out my youtube channel CFAIST1
Do I use the torrez calculator. Will it tell me the cut outs. And also how do I know where the port goes. Is there a picture it gives me?
Yes, use the Torres calculator. You will have to do the math and figure out where to put your port and cutouts yourself. It will give you a cut list.
I'm gonna hate
How do I even do the math lol. First time building a box, maybe not gunna turn out perfect but...its a start
Like how do you center a hole on a square? The box calculator will give you your port size and everything then just put everything where it needs to be. There's only so much that can be said over the internet, maybe watch a tutorial? The calc should give you everything you need.
I'm gonna hate
I didn't actuallly look at the box calculator yet. I didn't know what it gives you. But thanks
Give that a glance first, it should give you all the info you need to buy materials and build a killer box! :D
I'm gonna hate
  • Who's Online   0 Members, 0 Anonymous, 1826 Guests (See full list)
