Audio4Lyfe Posted June 1, 2012 Report Posted June 1, 2012 Hey guys, i have a pa d4000.4 running 1 set of polk audio mm6501 components. If i get another set of these components do you think my amp would be able to power both components sufficiently? Or do i need a bigger amp? Thanks for any of your help!! Heres the links: http://www.sonicelectronix.com/item_39894_Polk-Audio-PA-D4000.4-PAD4000.4.html http://www.sonicelectronix.com/item_15059_Polk-Audio-MM6501.html
HunterJohnson Posted June 1, 2012 Report Posted June 1, 2012 Personally I think it will just fine. i just dont understand why youre using a D class amp for components, you must just like dat bassss Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
Audio4Lyfe Posted June 1, 2012 Author Report Posted June 1, 2012 Thanks. The amp was recommended to me. It will be okay to run these speakers on the class d then? Or what other amp would you recommend?
Bump4life Posted June 1, 2012 Report Posted June 1, 2012 if it sounds good to you it is fine. personally i prefer a class a/b amp for fidelity but to be honest ive used both with those exact same speakers and they both sound fine. although class a/b i thought sounded better. personally i run those exact components on 150rms a sidde and they take the power fine. i think 75 rms would be fine. but let me say these speakers can get loud with power! Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
