new head unit bose original stock unit.
1998 Nissan Maxima stock BOSE system. My question is this. I am installing a new after market head unit JVC KD-R900. Are the stock speakers powered by the stock head unit, or @ speaker? Trying to aviod wiring it up to find out if it will work.
i THINK you need this
http://www.amazon.co...i/dp/B0007WTF5C
bose systems and the like, generally need a harness that has rca's on it. because the factory amp needs to get the signal through low level inputs (aka the rca cables connected to the pre outs on your aftermarket headunit). unless you do some difficult install work and bypass the bose amp completely, you wont be able to just hook the speakers up to the headunit.
  • 3 weeks later...
You need a SVEN4
Google
In the long run, if you plan on going big. It would be worth it to bypass the amp like kranny said. Take the amp out, get a 4 channel, and rerun your wires.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
  • Who's Online   0 Members, 0 Anonymous, 1213 Guests (See full list)
