Charging AGM Battery
So i have a quick question, i have a kinetik hc1800 in trunk wired up to stock batt up front. Now what im getting at, is what is the proper way of charging battery in trunk?
I am gonna disconnect my stock batt from agm(batt in trunk) as my charger has different settings for each. Until i can get another kinetik or just swap both batts out for some xs batts.
Now when charging batt, should i unplug my amp from it? Or just leave plugged in?
Will it harm my amps if i charge batt while the amps are still connected, or will they be fine?
Just wanna be on the safe side, and it never hurts to ask when you are in need of some answers. I have read a few posts and topics but haven't quite found the answer i am looking for
Under Construction
2011 Malibu 1LT
12k DDM Tuning HID's 55W
Soundstream 6.5 components(front)
Inffinitty Kappa 6x9's (rear)
Get rid of the stock battery. It will put a slow drain on the kinetik.
As for charging it: Just put it on an AGM compatible charger with the car and accessories off. No need to disconnect it or anything.
thanks for the info and i'm currently working on getting a kinetik for the front like a hc1400, or just swapping out for two xs power batts
Under Construction
2011 Malibu 1LT
  • Who's Online   0 Members, 0 Anonymous, 1019 Guests (See full list)
