if you really want to do it yourself get whatever glasspack/flowmaster/magnaflow/borla you want to use sawzall your OE muffler off remove the rest off exhaust after muffler off the hangers and just get some clamps and use red loctite on the nuts and threads. I after you cut the muffler off you can buy a 12 or 18 inch pipe to extend the cut pipe a little bit more to the back then add whichever muffler you get to that. Just get down there and think ahead take your time and make small cuts at a time rather than big ones that end up leaving you nothing to work with.
i would take a look and see what is out there for cat-back exhaust , bet there's a lot of direct fit stuff out there
A way to bust the glass in em is get em hot then spray water in em. That's what my dad and uncle said.
Yes Sir ... Works great ... Gives it a great tone
exhaust shops will not pull the cats ... mine is done cat - back ...
b-dubs89, I was just adding to your post ... not saying you was wrong or anything
wouldn't want to pull the cats on anything with down stream o2 sensors either , you would have a never ending check engine light . kind of hate down stream o2 sensors
