2K XJ Posted June 9, 2012 Report Posted June 9, 2012 Hey guys, so first off I would just like to say that I am a total noob to this subject so any help you can give me is greatly appreciated. I drive a 1999 Jeep Cherokee sport and from what I have read I have a 90 amp alternator. Recently I have been planning on doing a new system in the Jeep of 3 SA8 v2s on a SAZ1500. I have already bought the SA8s and am currently looking for a deal on the amp, but I know I will need to beef up the electrical in order to run the SA's to there full potential. That is where I need you guys' help. I don't know what upgrades will be sufficient for this system. Do I need a new HO alt? HO alt + battery/batteries? Or just add batteries? Thanks in advance. 1999 Jeep Cherokee SportLifted on 31'sPopcorn Sounds AX6000.1 w/ AA 500.1 "THE F1X" board4 Obsidian Audio OA15's C pillar wall @ 29hz ^^^work in progress^^^
bass_stalker Posted June 14, 2012 Report Posted June 14, 2012 my jeep is equipped with a 124 amp alt, and ive heard you can put an older grand cherokee alt in it with alittle modification. so if your looking for cheaper amps just see about an oem replacement because the mechman model/dc model for our jeeps is 500 bucks. for the front battery i would upgrade to a d3100 since its a direct replacement to the stock battery, and you would probobly only need 1 secondary battery mounted in back. as for wire use high quality 0 gauge for all of your connections and the big three upgrade JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
