Another Polyfil Question..
I understand it's basic purpose in this field. My question is, do the other characteristics of a larger box come with it? Does tuning and port area drop? Mechanical handling changes, etc.
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
Tuning will drop in ported boxes.
Port area has nothing to do with box size, so it stays the same. If you want to bring the tuning frequency back up, make the port shorter.
You would be guessing on mechanical power handling. The change in tuning alone could change the power handling.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
I mean you'd loose port area per cube.
Sub Amp: AB 450.1
XS D3100
Come on 150!
Which does not matter, since port area is NOT related to box size!!!
Current system:
Previous systems:
You got me as confused as a starving baby in a topless bar. I'm under the impression that box size is DIRECTLY related to port area. Port area is (most commonly) determined based on what? Box size. Otherwise, everyone would use the same size port no matter the Vb. Where am I thinking wrong with this logic?
Sub Amp: AB 450.1
XS D3100
Come on 150!
You are 100% wrong, just like many other people.
Port area is related to air velocity though the port, which is related to tuning frequency, cone area, and Xmax.
Think of this:
I put a BTL 18 in a 6 cuft box tuned to 32 Hz and feed it 4000 watts. Do you think a cheap 18 with 5mm of Xmax on 100 watts in that same box would need the same amount of port area?
Or can you explain why the same sub in 5 cuft vs. 6 cuft with the same tuning frequency would need a different amount of port area?
Current system:
Previous systems:
Think of this:
1) Be easy...
2) Thanks for the comparison/lesson.
3) I don't think there is an explanation.
Sub Amp: AB 450.1
XS D3100
Come on 150!
A couple of manufacturers gave some guidelines (which are pretty dang close in most cases) and related them to box size. Somehow these became the law that everyone lives by.
Now many people think if you have over 16 sqin per cuft it is only for SPL and will not play music correctly, or smaller ports extend the frequency response higher, and the list goes on.
Current system:
Previous systems:
  • Who's Online   0 Members, 0 Anonymous, 1151 Guests (See full list)
