Home Set Up???
Hello Everyone,
I would just like some input from people that actually know about the subject. I am trying to set up some car audio equipment that I have sitting in my house. I know that it won't sound as loud because its in an open room and not an enclosed car. I know the bass is going to fall off a lot and all that but i have this equipment sitting out so why not put it to use. I am trying to power a Hifonics BRZ1700 and a zeus amp for the highs.... Basically have some 6.5 rockford components and a SA-15 in a #.5 Cube box tuned to 28hz i believe. I have a Kinetik 2400 and I am aware that i can power everything up in my room with the battery but if I buy a Kinetik 80 amp power supply to add it to the equipment would it be enough to keep up with the power demand or would I only be able to play at half power? Any input is welcome.
Thank You
It's probably going to be easier to just buy amplifiers meant for home audio.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
I understand where you're coming from but i have these amps and the kinetik battery just sitting there so i would like to put them to use plus i think it would save me money just buying a power supply rather than buying 2 amps that produce the same amount of power.
I don't know much about those power supplies, but if they do put out 80 amps, then I'd half power is about right.
But really, for the price of that power supply, you could get a couple decent home audio amps...
the power supply should be around 250 at my local audio store... Can you give me some suggestions for an amp? would i need 2 different amps for the sub and the highs???
I suggest using a home receiver to power your mids/highs. most home speakers are an 8ohm load around 75wrms or so, so using a 4ohm speaker should be perfect.
some ideas for you
Im looking for something along those lines.... I have a box for the Sub now just going to build something for the mids and highs.
Buy a Behringer EP4000 for 300 off of Ebay. Does 2.5K RMS at 4 Ohms. Or buy a Ep2000 for 220. Does 1.3k at 4 ohms.
Thats a pretty good price for an amp.
