Box build
atudela45
i have 2 Massive Audio CW 12s and currently have a 4th order box that is tuned to 45hz. i recently started going to more comps and need a "more fit" box for bass! I have a 2001 grand prix 4 door and my back seat has the center part that folds down to get into the trunk. one good thing about the box i have now is that the port comes flush with the seat so when you open it up you have a port firing into the cab. is there a way i can have the subs in a lower tuned box with the subs facing the back and the port firing out the open center? or the subs facing up?
for a 4th order your tune is probably to low already, and you want to lower it more?
you should be around 47-50hz depending on what you sealed side is tuned to,
if you want to go to a standard ported box that's a different story,
if i were you i look at aero ports or a removable port so as you can change the tune on the fly for daily and comp,
put the pic on photo bucket or similar,
then cut the link, click the square that looks like a picture in the toolbar when typing and post link there,
but you need to delete the img at the start and end on the link before posting it
  • Who's Online   0 Members, 0 Anonymous, 1477 Guests (See full list)
