First box. No clue what to do
Here is a suggestion very much like the above:
Enclosure Specifications:
Fb = 32.048 Hz
Vb = 2.125 ft^3
External Height = 11.5 in
External Width = 35 in
External Depth = 17 in
Port Width = 3 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front & Back = 35 x 11 1/2
Left & Right Sides = 15 1/2 x 10
Top & Bottom = 35 x 15 1/2
L Port Internal Assembly Parts:
Front to Back = 12 1/2 x 10
Extension = 14 x 10
Assembly guide (generic dimensions):
Let me know any questions.
any suggestions with what type of screws, how many and type of glue?
Fb = 32.048 Hz
Vb = 2.125 ft^3
Port Width = 3 in
Cut Sheet List:
Extension = 14 x 10
MDF screws, Titebond II wood glue.
Fb = 32.048 Hz
Vb = 2.125 ft^3
Port Width = 3 in
Cut Sheet List:
Extension = 14 x 10
If you cut the wood straight you can do with out screws and for glue tightbond 2
do i need caulk? if so, when do i apply that?
Fb = 32.048 Hz
Vb = 2.125 ft^3
Port Width = 3 in
Cut Sheet List:
Extension = 14 x 10
do i need a double baffle? if so how much of an impact would it have if i just doubled it? will tuning go up or down?
If you get perfect cuts, that's your best bet against leaks, You apply the sealant once the glue has dried in a given section. Get your cuts done if you don't have proper equipment, Home Depot does that service.
You don't really need a double baffle for those subs, you may place a front to back crossbrace between the subs if you want, in any case I can issue a double baffle version if you feel uneasy. Most people ask the opposite question..lol.
They will do straight cuts, let them know you really need precise cuts, Termlab tests by members on here have shown that 45s hurt SPL in many cases, the one in the port turn though is helpful to ease airflow, the figure show a slant in the inner corner of the port turn, if you can't do the slant, you can sand it, just taking away the sharp edge. I would place a dowel rod between the subs front to back although is not strictly necessary.
  • Who's Online   1 Member, 0 Anonymous, 1366 Guests (See full list)
