Ray-ban Posted June 18, 2012 Author Report Share Posted June 18, 2012 Here is a suggestion very much like the above: Enclosure Specifications: Fb = 32.048 Hz Vb = 2.125 ft^3 External Height = 11.5 in External Width = 35 in External Depth = 17 in Port Width = 3 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front & Back = 35 x 11 1/2 Left & Right Sides = 15 1/2 x 10 Top & Bottom = 35 x 15 1/2 L Port Internal Assembly Parts: Front to Back = 12 1/2 x 10 Extension = 14 x 10 Assembly guide (generic dimensions): Let me know any questions. any suggestions with what type of screws, how many and type of glue? Quote Link to comment Share on other sites More sharing options...
donpablo Posted June 18, 2012 Report Share Posted June 18, 2012 If you cut the wood straight you can do with out screws and for glue tightbond 2 Quote 2015 F-150 Platnuim Link to comment Share on other sites More sharing options...
Joe X Posted June 18, 2012 Report Share Posted June 18, 2012 Here is a suggestion very much like the above: Enclosure Specifications: Fb = 32.048 Hz Vb = 2.125 ft^3 External Height = 11.5 in External Width = 35 in External Depth = 17 in Port Width = 3 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front & Back = 35 x 11 1/2 Left & Right Sides = 15 1/2 x 10 Top & Bottom = 35 x 15 1/2 L Port Internal Assembly Parts: Front to Back = 12 1/2 x 10 Extension = 14 x 10 Assembly guide (generic dimensions): Let me know any questions. any suggestions with what type of screws, how many and type of glue? MDF screws, Titebond II wood glue. Quote Link to comment Share on other sites More sharing options...
Ray-ban Posted June 18, 2012 Author Report Share Posted June 18, 2012 Here is a suggestion very much like the above: Enclosure Specifications: Fb = 32.048 Hz Vb = 2.125 ft^3 External Height = 11.5 in External Width = 35 in External Depth = 17 in Port Width = 3 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front & Back = 35 x 11 1/2 Left & Right Sides = 15 1/2 x 10 Top & Bottom = 35 x 15 1/2 L Port Internal Assembly Parts: Front to Back = 12 1/2 x 10 Extension = 14 x 10 Assembly guide (generic dimensions): Let me know any questions. any suggestions with what type of screws, how many and type of glue? MDF screws, Titebond II wood glue. If you cut the wood straight you can do with out screws and for glue tightbond 2 do i need caulk? if so, when do i apply that? Quote Link to comment Share on other sites More sharing options...
Ray-ban Posted June 18, 2012 Author Report Share Posted June 18, 2012 Here is a suggestion very much like the above: Enclosure Specifications: Fb = 32.048 Hz Vb = 2.125 ft^3 External Height = 11.5 in External Width = 35 in External Depth = 17 in Port Width = 3 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front & Back = 35 x 11 1/2 Left & Right Sides = 15 1/2 x 10 Top & Bottom = 35 x 15 1/2 L Port Internal Assembly Parts: Front to Back = 12 1/2 x 10 Extension = 14 x 10 Assembly guide (generic dimensions): Let me know any questions. do i need a double baffle? if so how much of an impact would it have if i just doubled it? will tuning go up or down? Quote Link to comment Share on other sites More sharing options...
Joe X Posted June 18, 2012 Report Share Posted June 18, 2012 If you get perfect cuts, that's your best bet against leaks, You apply the sealant once the glue has dried in a given section. Get your cuts done if you don't have proper equipment, Home Depot does that service. You don't really need a double baffle for those subs, you may place a front to back crossbrace between the subs if you want, in any case I can issue a double baffle version if you feel uneasy. Most people ask the opposite question..lol. Quote Link to comment Share on other sites More sharing options...
Joe X Posted June 18, 2012 Report Share Posted June 18, 2012 If you just add a baffle layer tuning would go down but will probably be inaudible. Quote Link to comment Share on other sites More sharing options...
Ray-ban Posted June 18, 2012 Author Report Share Posted June 18, 2012 If you just add a baffle layer tuning would go down but will probably be inaudible. I guess I'm not going with double baffle. Haha does home depot cut out the holes for the subs as well? Appreciate your help! Quote Link to comment Share on other sites More sharing options...
Ray-ban Posted June 18, 2012 Author Report Share Posted June 18, 2012 45's and sanding. What spots do I want 45's and what edges do I sand? when sanding the sharp edges of the port, is it possible to over sand? Quote Link to comment Share on other sites More sharing options...
Joe X Posted June 18, 2012 Report Share Posted June 18, 2012 They will do straight cuts, let them know you really need precise cuts, Termlab tests by members on here have shown that 45s hurt SPL in many cases, the one in the port turn though is helpful to ease airflow, the figure show a slant in the inner corner of the port turn, if you can't do the slant, you can sand it, just taking away the sharp edge. I would place a dowel rod between the subs front to back although is not strictly necessary. Quote Link to comment Share on other sites More sharing options...
