Ray-ban Posted June 18, 2012 Author Report Posted June 18, 2012 So I won't mess anything up when sanding the outside of the port? For example over sanding or under sanding. If I plan on Adding a dowel, what size do I use and do I screw it on or glue it on? Quote
Joe X Posted June 18, 2012 Report Posted June 18, 2012 If you mean sanding the internal and external ends then for all practical matters no if it was kerfed then the effective length of the port would be reduced somewhat, the wooden rod can be whatever you think is necessary aabove 1" diameter both glued and screwed Quote
Ray-ban Posted June 18, 2012 Author Report Posted June 18, 2012 If you mean sanding the internal and external ends then for all practical matters no if it was kerfed then the effective length of the port would be reduced somewhat, the wooden rod can be whatever you think is necessary aabove 1" diameter both glued and screwed i hate to ask but do you mind putting up dimensions for a double baffle tuned at 30-32hz? im gonna start building today and im gonna go with the double baffle design. Thanks! Quote
Joe X Posted June 18, 2012 Report Posted June 18, 2012 Ok no problem: Enclosure Specifications: Fb = 32.062 Hz Vb = 2.152 ft^3 External Height = 11.5 in External Width = 35 in External Depth = 17.75 in Port Width = 3 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 35 x 11 1/2 Left & Right Sides = 15 1/2 x 10 Top & Bottom = 35 x 15 1/2 L Port Internal Assembly Parts: Front to Back = 12 1/2 x 10 Extension = 12 3/4 x 10 Don't think you need the crossbrace with the double baffle. Quote
Ray-ban Posted June 18, 2012 Author Report Posted June 18, 2012 Ok no problem: Enclosure Specifications: Fb = 32.062 Hz Vb = 2.152 ft^3 External Height = 11.5 in External Width = 35 in External Depth = 17.75 in Port Width = 3 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 35 x 11 1/2 Left & Right Sides = 15 1/2 x 10 Top & Bottom = 35 x 15 1/2 L Port Internal Assembly Parts: Front to Back = 12 1/2 x 10 Extension = 12 3/4 x 10 Don't think you need the crossbrace with the double baffle. Thanks a lot!! I'll post a pic when I'm done. Quote
Ray-ban Posted June 20, 2012 Author Report Posted June 20, 2012 how do i screw the pieces together? I feel like ill split the wood? Quote
Joe X Posted June 20, 2012 Report Posted June 20, 2012 Ok as before use MDF screws, You will need to predrill before placing the screw to avoid the splitting. Quote
