I wish I knew someone with a TL!
I agree with the closing oif the air vents, ive used it and gained from it
Also, be sure your power hungry AC is off
be sure that no interior or exteriot lighting is on
In other words, anything that would use electricity that isn't needed for your stereo or your car running.
rev and hold your engine RPM level around 2000- unless limited per class
SOme things I have seen give gains and work, i have not tried yet.
Romoving all floor mats in the car (carpet),
If your box is carpeted remove carpet
anything carpet acts as a sound absorber, so anything that can easily be removed get rid of it.
Drink beer during the entire event
Flipping your visors down (seriously) when your at full tilt, and the DB is holding, try flipping the visors
i gain cooling the cabin an leaving rear a/c on...moving seats forward,flipping visors etc will gain also
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
I can agree with keeping the cabin cooler, but when if comes to the additional amps needed for a high powered system during a run, I would keep it off so all power is applied to the amps
yep, every car is different, without a termlab to test those things out before the show, i wouldn´t suggest closing any vents or moving seats at all, my swift dropped a full db just by moving he seats forward while my explorer gains a few tenths by doing the same thing...
  • Who's Online   0 Members, 0 Anonymous, 3689 Guests (See full list)
