kbsmoker Posted June 21, 2012 Report Posted June 21, 2012 Mb quart discus 4125 is what eric was using Quote www.dcsoundlab.comyoutube video's kbsmoker2011 MECAOH AS3 Champ 147.5OH DB2 Champ 125.9WF AS3 3rd 147.3WF DB3 2nd 128.3 SystemPioneer AVH-P4300DVD2 sets Fusion Encounter 6.5 componentson Crunch Ground Pounder 1200.418" DC NEO on DC 5.0KKnukonceptz 1/0 through outBig 3 all 1/0XS D6500under hood D3100 in the backMechman 270....rebuilt by Ohio Generator
AA98hoe Posted June 22, 2012 Report Posted June 22, 2012 (edited) I told ya before bret..i run zapco 750.2s.. the black ones are best..in the monring they wont come on till voltage drops to 16.2 but after that they work fine.. one of them popped last weekend it was the silver one..so i bought a mbquart onyx 2x100 and it works great and sounds good Edited June 22, 2012 by dc98hoe Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
bre2ts Posted June 22, 2012 Author Report Posted June 22, 2012 Mb quart discus 4125 is what eric was using Thanks pro I told ya before bret..i run zapco 750.2s.. the black ones are best..in the monring they wont come on till voltage drops to 16.2 but after that they work fine.. one of them popped last weekend it was the silver one..so i bought a mbquart onyx 2x100 and it works great and sounds good I know I know and I'd use the zapcos but I don't want to charge that low. But it seems the onx. Seriously can handle higher power so I guess I,ll use them Quote Feedback 1 | Feedback 2 you win some, you lose some
