I will be running a Soundstream TX1.2000D and a JL Audio JX360/4.. My JL is pushing around 50x4. The Soundstream will be pushing 1500 on 1 ohm. I have a 2004 Pontiac Bonneville with a stock 140 amp alternator. Would I be okay? Thanks
What battery would you recommend? My battery isn't stock now but I can't honestly say what it is..can't remeber. If i added another battery wouldn't that meant that the alternator would be trying to charge two and cause more stress?
I've ran around 2k in the past, stock alternator, extra battery in the trunk, with no problems. Now, not to leave out the fact that you will experience voltage drop which will keep your amps from being capable of they're full output.
I ran 2 batteries, stock alternator, never had one problem, car was an 01 pontiac grand am, I believe the same alt
What kind of voltage drops did you experience?
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
down to 12v, so missing out on a couple volts, nothing major, but can add up to quite a few watts,
I ran this type of setup for several years, no dead batteries, no alternators went bad. In fact, never had to replace and alternator on the grand am and always had an extra battery and around 2k hooked up to it, had the car for 8 years
Edited by purplesyrup
What kind of battery would you recomend upgrading to to put in the trunk?
  • Who's Online   1 Member, 0 Anonymous, 738 Guests (See full list)
