Y-splitters are downright your cheapest option. If you decide to go with Y-splitters then I think you would have to turn of the LPF on the head unit and set that through the amplifier.... not 100% sure so anyone correct me because I'm not sure if that's how the low pass filter works. but yea, Y-splitters, one splitter will be left and one will be right. simple. you don't need to buy 4 y-splitters because you only have 2 rca connections on your head unit
eq imo..then you will have front rear and sub out plus equalisation.. i get my arc eq for a lil over 100
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
