why is my amp making a high pitched sound?
There may be a bad fan in the amp. If it is warrantied, send it back.
if not, open it up and remove the ground wire from the fan and wrap electric tape around the connection points to be safe.
no fan on it, but that would be sweet if thats what it was lol.
some amps do that when they clip
Ding ding.
I've noticed on a majority of the amps that I've tuned with the DD-1, when the clip indicator turns on on the DD-1, I can hear a squeal coming from the amp. Back off the gain, clip light goes of, squeal goes away.
How did you tune your amp?
i didnt tune it really, i just plugged it in to see if it worked, it doesnt make the noise for like a min or so after i turn it on
Hmm.... Well what ohm load do you have it wired at?
Edited by HatersGonnaHate
You keep shooting down all my ideas lol. I was gonna say switch the ohm load to 2 lol. I wouldn't trust it at 1ohm though, just because it's already making a noise, I wouldn't want you dropping the ohm load and completely frying it.
So for now, check all grounds, open the amp up and make sure there are no loose connections, blow the dust off it again, cross your fingers lol
well i checked everything and it looked good. so i blew it out with the compressor and it was dusty as shit lol. but i think that was the problem all the dust. its really just a feint high pitched noise.
How many PSI did you have coming out of the compressor???
IDK i didnt put it right up to it and blast it lol. i just blew it over the top of it to get all the dust out. Why is the compressor a nono? i use it to blow out my pc case all the time with no problems
Edited by Redcorn245
It's a no-no just for the pressures that it can put out, especially a no-no for electronics. Should have used a can of keyboard/air duster. Something could have been blown loose with the compressor
  • Who's Online   0 Members, 0 Anonymous, 1755 Guests (See full list)
