hows it goingLH-FF97S-KS-SET.jpg folks will a hid kit work with these head lights ?
dcaudio.jpg ALLAH's the most gracious, he made the universe the most spaciousSeen and heard in all places, but still appear facelessEmbraces all races, all caste and all casesIn every spec of life he's the substance of all tracesSMDsigbannr9.jpg
Most HID sets are kits, so typically you mount the ballast in the engine bay somewhere and then replace the bulbs. As long as you can swap bulbs in that enclosure, I don't see it being a problem.
2k6 Dodge Ram 2500...CUMMINS POWERED - SOLD
im pretty sure that i can do that but just making sure thanks
it will but keep in mind you will lose you high beams unless you get a bi-xenon kit
current set-up:
headunit: kenwood excelon kdc-x891
mids: front: mb quart reference 6.5s rear: pioneer TSA941 6x9
mid and high amp: performance technique ICBM-773
sub amp: kicker 08zx2500.1
subs: (2) 08s15l7d2
4.25 cubic foot sealed box
big 3 all in hooker 1/0 wiring
Sacrifice your car to the Audio Gods and DBs will come.
make sure you get a d2r bulb not a d2s. the d2r bulbs are meant for reflector housings because it will not scatter the light everywhere and blind people. only use a d2s bulb in a projector housing.
thats true....blind you EVEN more... if you were to get a d2r you would have to rebase the housing or bulb i forget..it would definately help but be alot of work...
current set-up:
subs: (2) 08s15l7d2
no? a d2r bulb just has a metallic strip on it to prevent the light from scattering up to blind people. thats really the only difference between the two bulbs you dont need to rebase it or anything. simple as this. d2r=reflector housing, d2s=projector housing. d2s doesnt have that strip letting the light to scatter everywhere but it focused and level with the projector lens.
i understand that but a d2r bulb or "capsule" wont just simply fit into the 9007 housing.
look at how the bottom of the bulb is.
compare that to this:
where it is held on by the housing itself is completely different. so if a d2r were to work, you would need to rebase the bottom or base to fit the 9007 housing
current set-up:
subs: (2) 08s15l7d2
yeah you just get a d2r 9007 bulb for reflector housing and d2s 9007 bulb for projector. i dont think ive seen a conversion kit that just gives you the bulb without the base. you specify which bulb/base/temp you want when you buy a kit.
