Jessica Posted June 24, 2012 Report Posted June 24, 2012 I may be adding a second amp to my system, I could slave it or gain match. I'll probably gain match since i will be running dual4 subs and don't want to wire to 1ohm or 4ohm. So i think for my needs i would be best with each amp seeing 2ohms.(yes, i could get dual 2's but i think i can get a good deal on some dual 4's) Anyway, Would i be safe using only a dimm and AC volts to match, or should i full out clamp? I was planning on setting my gains with the dd-1/ -10db tone and pac-lc1 at max, finding max unclipped for each amp, then match to the lowest output for saftey and junk. Sound right? Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
