most likely the two tweeters (if both actually do something) are set up with a 6db per octave high pass filter
they may be the same or they may be different
for example the "mid" might play 3k and up and the "tweet" will play 6k and up
there is a lot of redundancy in this
a proper three way band passes the mid
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
thats what i was assuming, so i cant really see them causing an audible difference in sound
