chrisj Posted June 25, 2012 Author Report Share Posted June 25, 2012 Maximum specs that I came up with was 42x20x18 which I think puts the box around 7 cubes. In the Amp area what would you recommend @ x Quote Link to comment Share on other sites More sharing options...
Joe X Posted June 26, 2012 Report Share Posted June 26, 2012 Consider this suggestion for your subs and dimensions: Enclosure Specifications: Fb = 36 Hz Vb = 6.05 ft^3 External Height = 20 in External Width = 42 in External Depth = 18 in Port Width = 4 1/2 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Top & Bottom = 42 x 18 Left & Right Sides = 16 1/2 x 18 1/2 2x Front = 18 3/4 x 18 1/2 Back = 42 x 18 1/2 Shared Port Internal Assembly Parts: 2 x Front to Back = 14 1/4 x 18 1/2 Quote Link to comment Share on other sites More sharing options...
Miguels Posted June 26, 2012 Report Share Posted June 26, 2012 nice design joe subs up port back is how i have it in my expo Quote my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
chrisj Posted June 26, 2012 Author Report Share Posted June 26, 2012 This is on point! Preciate it. Stick with the same amp you think? Quote Link to comment Share on other sites More sharing options...
Ddub847 Posted June 26, 2012 Report Share Posted June 26, 2012 how much power does it do Quote Link to comment Share on other sites More sharing options...
chrisj Posted June 26, 2012 Author Report Share Posted June 26, 2012 True 1500 as far as I know Quote Link to comment Share on other sites More sharing options...
chrisj Posted June 26, 2012 Author Report Share Posted June 26, 2012 Hey Joe could I use one sheet of mdf for this build? Quote Link to comment Share on other sites More sharing options...
Joe X Posted June 27, 2012 Report Share Posted June 27, 2012 Hey Joe could I use one sheet of mdf for this build? A 4x8 sheet has slightly more surface area than the box build needs but hardly you will be able to cut so efficiently. Quote Link to comment Share on other sites More sharing options...
yUmadBro Posted June 27, 2012 Report Share Posted June 27, 2012 I dont think that amps getting a true 1500 Quote Link to comment Share on other sites More sharing options...
