If the dimensions are bottom depth 36 and top depth 28 then yes if the dimensions are just depth 28 then no, if the depth is just 28 then I will have room behind the box to put a Amp so either I don't mind which ever is easier.
im no fantastic box designer, but this seems to work. 5" pvc ports. you'd have to get some pvc U tubes to bend the ports inside the box. or make the ports slightly external, which will affect the box size/tuning numbers slightly.
i forgot to delete the 3 in # of common port walls. that only applies to slot ports, not circle ports. having that number there doesn't affect anything.
edit: i'd probably put a second baffle on it, just to keep the flex down. those little guys are pretty beeft
Edited by Kranny
well I don't know what a Second Baffle is so maybe instead of that we could drop the height down a bit more rather then have it 1 inch from the top, I was thinking more 4 inches from the top so it has clear room. If you could design a box and maybe sketch it out on Google Sketch Up and send me the dimensions then I can be sure I will have a good box and not need to worry if its wrong.
the baffle is the piece of wood that your subs mount to
yeah some people make the lower/first baffle sub cutouts like normal so that the sub sits normally. then the second baffle will have a slightly larger cutout that will make the sub appear flush.
like this
http://www.bcae1.com/spboxnew2.htm I used this website when i started building boxes....this should help you with the basics and then some. Good luck!
Audi A6 Quattro Wangin' Wagon
Pioneer Premier DEH-P5901B Headunit w/ IPOD control
American Bass SQ5.25 in the Doors
Compression Drivers and Horns under Dash
2 American Bass SQ475's for Mids/Highs4 American Bass HD 15's
American Bass 500.1
17cuft 3/4" Double Baffle Birch Enclosure 240sqin port @38hz1/0 AWG Stinger big 3 under hood4 Runs of 1/0 AWG Stinger Power and Grounds
Stinger Fuseblocks(3) XS Power D3100 Powercells120 amp AlternatorBlue Streetglow Underglow and Interior with Music InterfaceEscort Passport 8500 X50 HardwiredScanGuage II with voltage Readout
Ok thanks guys ill look into it, ill have to make a new box because mine failed once again. Every time I spend like an hour making a box for someone to just point something out that's wrong. :(
  • Who's Online   0 Members, 0 Anonymous, 624 Guests (See full list)
