cbianco Posted June 27, 2012 Report Posted June 27, 2012 I found an amp, at a good price but it doesn't quite match up with my sub. Single sub DVC4 wired down to 2ohms, 500 watts rms. Mono amp 1000 watts rms @ 1ohm. If I run the mono amp @ 2ohms will it be ok? I assume that an impedance of 2ohms on this amp will give me 500 watts, is that correct? I know it's important to match amp's & woofer's impedance but will this mismatch cause any harm to my system (besides not getting the most out of the amp)? EDIT: The reason I ask is, the amp doesn't give a 2ohm or 4ohm rating ONLY a 1ohm rating. Chris
RickyFriery97 Posted June 27, 2012 Report Posted June 27, 2012 yes you can run @ 2ohm no problem 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
onelivinlarge Posted June 27, 2012 Report Posted June 27, 2012 WOW.... but yes u can run it at 2 ohms it will actually be easyer on the amp plus after rise it probably be like 4 or somthing 1) lookj to left 2) NOTICE BLKUE 3) ME > Y9OU 4) that is all
cbianco Posted June 27, 2012 Author Report Posted June 27, 2012 Thanks for the confirmation guys. Christopher
