Max Unclipped Power To SA8 V1 & V2?
I have 2 sa8V2 running Rockford Fosgate 1000.1 bdcp. running 1 ohm. no issues, and pushes massive air for two 8" subs. ( I say massive, simply because I can do a hair trick with my setup in the trunk of a BMW through a ski port... without the trunk being sealed off.... seems massive to me LOL)
I would love to see a 2 8 hair trick
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
don't get me wrong.. it's nothing like most of the hair tricks on here.... Mind you they are two 8 inch subs.. but playing decaf off of my phone. I cannot make a video while connect.. When my wife gets home next week. (she has my camera) I will take a video for you failed attempt of a hair trick or not. I will try and post a video.
Ive got an NS-1 to 2 of them. this box they are in is about .6 per woofer with a 4" aero, I just rebuilt a box to 1cube per woofer with 40sq" of port and it only takes that power around tuning, but under tuning i have to turn the HU down a couple clicks.
I'm impressed with the little guys!
im running 3 SA-8 V2's to a monoblock 5000 watt boss amp, turned amp down and clamped power output, running approx. 1500 watts to each wired down to 1 ohm, they handle it well, they are in a 3.2 cu/ft box ported at 34 htz. if you run a ported box make your port plenty big, these move A LOT of air
lulz...boss amp. I bet them 8's are handling that 5kw very well.
09 Challenger R/T (Audio system under construction):
  • Pioneer AVH-X4500BT (PAC RP4CH11 harness)
  • (2) Sundown Audio SA-8v2 (inverted)
  • CT Sounds AT1400.1D
  • XS Power D3400
  • 40 sq ft. Audiotechnix deadener
  • 1/0 Audiotechnix wiring
  • stock Boston Acoustic 7 speaker amplified system (for now)
  • Sealed trunk enclosure
Build log:
http://www.stevemeadedesigns.com/board/topic/178399-slammed-dodge-challenger-sundownct-sounds-build/
TEAM GOAT
  • Who's Online   0 Members, 0 Anonymous, 1621 Guests (See full list)
