BG............
Is this a pretty Decent Panel....for 60 bux
It bigger than Ill probably ever need.....but for 60.00,seems like a good price
Lowes
GP- that is ok for a panel replacement, but you don't need to replace the primary, just add a secondary-sub panel..
Besides, u would need to add a 125A breaker to your main panel and need 1/0 aluminum conductors to power that panel correctly..
I will look around for you, all you need is a 60 amp sub panel, I seen them around home depot for like 25 bux, the 60 amp breaker to put in your main panel is prob around 14 bux, and you will need to run 6/3 romex w/ ground to power it up.
When u have time post up the breakers amp ratings you have, and double check the a/c unit outside to make sure it's not oversized - it happens alot.....
I will le you know if your main panel can handle the sub panel without overloading your ish.... gotta keep that house of yours for at least a few years ,lol.....
I no longer live by tha sword, I'm living tha good life cuz I live it for the Lord. God is good, all tha time...
