Is it possible to skip the isolator and run a power wire straight from my alt to my battery in the back and keep the power wire that goes to my front battery too?
Just curious because I don't have awhole lot of room under my hood for an isolator.
1998 Ford Contour
Head Unit: Pioneer DEH-P8400BH
Front/Rear Door Speakers: Alpine SPR-68 (Type-R 6x8)
Door Speaker Amplifer: Kicker ZX650.4
Subwoofers: 1 SSA Icon 12"
Amplifier: MB.Quart 1.1500d
Second Battery: XS Power D925
why use a isolater?
2007 Ford Ranger
(ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES)
K&N Performance Air Intake
Massive Audio D2400 Mono Amplifier
2 Custom Built 8" Subwoofers in Ported Enclosure
Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed)
4 - Pioneer TS-A6886R 6" X 8"
2 - SMD Heavy Duty Single ANL Fuse Blocks
2- Stinger SPP1200 Dry Cell Batteries
JL AUDIO Interconnects
2/0 Gauge Big 3
ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals
ILL Customz 1/0 to 4 Gauge Power / Ground Reducers
Factory Alternator
__________________________________________________________________________________________________________________________________
2002 Cheverlot Monte Carlo SS - (Deceased)
2 - Rockford Fosgate Power 1501BD
1 - Rockford Fosgate Power 851x
Rockford Fosgate Power 6 1/2 Components
Rockford Fosgate Power 3 way 6x9
2 - JL Audio W7 13.5" Subwoofers (Sealed)
Pioneer AVH-P4400BH In - Dash DVD Player
Pioneer AVIC - U250 - Add-on GPS Navigation System
Audio Control 6XS 4 Way Crossover / Line Driver
Ohio Generator 200 Amp Alternator
3 - Stinger SPP1200 Batteries
1 - Optima D34/78 Battery
I always thought they helped with regulating voltage? I guess I really don't know, thats kinda why I was asking. I just know that running Wet Cell with AGM in parallel is not good.
1998 Ford Contour
gotcha .. i always thought a isolater is used if you was goin to run radio with car off so u dont kill front battery that would start the car. i could be wrong though.someone with better knowledge will have better answer if im incorrect
Edited by fosgatefan821
2007 Ford Ranger
2/0 Gauge Big 3
Factory Alternator
and yes from reading on here i learned it is not good to run wet and agm batteries
2007 Ford Ranger
2/0 Gauge Big 3
Factory Alternator
what i thought too
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
Well basically what I would do is run a power wire straight to my front battery from my alt, and then a power wire straight to the back battery from the alt and not even connect the front battery with the back. It would act in the same way as an isolator, kinda.
1998 Ford Contour
ISOLATOR DONT WORK FOR CAR AUDIO..THEY CREATE RESISTENCE
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
personally i would not wire it like that.. i dont know if it would cause any issues but i wouldnt do it myself
2007 Ford Ranger
2/0 Gauge Big 3
Factory Alternator
So... This and This are no good?
1998 Ford Contour
  • Who's Online   0 Members, 0 Anonymous, 2492 Guests (See full list)
